> Cylinder Head 24-1003015-g (24-1003015-Г)
Jirijirkas
сообщение 2018.12.16 20:38
Авто: ГАЗ-21Т '1966/2018
Страна: Чехия
Из: Прага
Был(а): 2025.01.19 8:57
I want to ask you. I bought the car with engine nr. 21A*443271* and cylinder head nr. 24-1003015-G. I read somewhere, that the both (engine and head) are intended for a compression ratio 6,7 (ei. for 76 octane petrol). I do not know, if the head has been modified for high octane petrol, but I suppose no.
So, what is my questions: If the head has been no modified yet, is it really intended for 76 oct. petrol? What type of spark plugs should I use for this head? If I want to use 95 oct. petrol, is the height, which I need to remove, 3,5 mm? And can I use the same spark plugs after modifiing?
Of course, before cutting the head, I want to ask service station for measuring the compression ration.
Elviis
сообщение 2018.12.16 22:29
Из: Мариуполь
Был(а): 2023.07.27 9:11
You have a cylinder head from Volga GAZ-24. To make it normal to drive on 95 gasoline, you need to cut it from the bottom so that its height is 93.5 - 94 mm. Make 94, it will be normal, there will be a little space if you ever need to grind.
Everything is simple, the height of the head should be 94 millimeters, this is for 93 gasoline, it is well suited for gasoline 95.
if your head has not been cut, then it has a height of 98 millimeters, then this is for gasoline 76
A spark plug can be BRISK L15Y or close to them of any other company, if the Soviet A-17, will be normal for 95 gasoline and a head height of 94 millimeters.
Just do not forget, if you cut the head, then you need to shorten the valve tappet all 8 pieces. You remove the steel cap, cut the barbell, usually 3 millimeters are enough, and you put on the cap. Otherwise you will not be able to adjust the valve.
[Отредактировал Stirlitz - 2018.12.17 17:48]
сообщение 2018.12.17 17:49
The above is correct.
Только свеча зажигания — spark plug.
сообщение 2018.12.17 19:18
Да и только вышеуказанные свечи нам не подойдут - у них длинная юбка.
Нам нужны типа:
- BRISK classic N17 - ГАЗ, ЗИЛ, УАЗ (короткая юбка)
http://www.brisk.ru/katalogi/svechi-zazhiganiya/super
Jirijirkas
сообщение 2018.12.17 19:20
Страна: Чехия
Из: Прага
Thank you for your reply. I first measure the head. Then I will read everything about cutting the head. I saw that there is a lot of information on this forum about the cutting the head.
Elviis
сообщение 2018.12.17 22:46
Из: Мариуполь
In order to cut the head, you need to give it to specialists and say how much you need to cut, and they already know how to do it. As for the candles, yes, I was wrong, those candles that I indicated are long candles, they were on my VAZ-2108, I was wrong when I looked at the packaging from them. Candles BRISK NR17YC well fit you
сообщение 2018.12.18 17:11
Вадим, да не candles же, а spark plugs.
Elviis
сообщение 2018.12.18 18:30
Из: Мариуполь
Ну не знаю… Турки нам привозили свечи накала для дизеля АДГ, писали candles )))) Думаю и так и так понятно))))
сообщение 2018.12.18 18:57
Ага, турки — авторитеты в английском языке. Ещё бы на китайские инструкции на английском сослался. Кому понятно, а кому нет.
Elviis
сообщение 2018.12.18 20:15
Из: Мариуполь
biggrin.gif ну мы их поняли))))
Ustrilu
сообщение 2018.12.18 20:42
Из: Бессарабия
Был(а): 2023.03.13 19:25
Простите мне маленький оФФтопик… помните фильм, кажется " Уроки французкого" назывался, где училка дома репетировала с учеником… закончили урок - игрой о пристенок, там уже ученик был в фаворе: - Чика на чику - равно чика несчитова. biggrin.gif
сообщение 2018.12.18 21:02
Да. По книге Валентина Распутина.
Да, по сабжу: на Brisk N17 мотор работает хорошо (несмотря на то, что их принято ругать). Біли какие-то А11 из коробки россыпью, были Ween - всё как-то не то пальто.
сообщение 2018.12.19 0:05
Турки может что-то знают…
Ну что б ещё понятней, донесу и свои 5 коп.: мы говорим о свечах, что для авто, а есть ещё что в жопу вставляют - на наш слух одинаковы, а для буржуев звучат по разному: biggrin.gif
Candles "Relief": reviews, composition, contra-indications
Today, many people suffer from unpleasant sensations in the anus.
Elviis
сообщение 2018.12.19 9:01
Из: Мариуполь
laugh.gif laugh.gif laugh.gif laugh.gif ну это мне еще рановато знать, не горю желанием laugh.gif laugh.gif laugh.gif laugh.gif laugh.gif
сообщение 2018.12.19 10:15
Я тебе скажу по другому: не обязательно вставлять, чтобы знать. Или ты поддерживаешь принцип учиться на своих ошибках ? biggrin.gif
Elviis
сообщение 2018.12.19 11:11
Из: Мариуполь
Gazik
сообщение 2018.12.19 16:13
Авто: ГАЗ-21Л 'август.1963
Из: Херсон
Был(а): 2025.09.13 22:31
Те свечи которые ректальные, для буржуев это "suppository" у нас их тоже называют суппозиториями (хотя некоторые пожилые люди так же называют свечами, жаль что некоторые даже их в церковь носят и пытаются перед иконой поставить, и с криком говорят что "не горят", и тогда провизору приходится объяснять что, куда и в какое отверстие вставлять, а инструкцию все равно не читают, хотя очень удивляются, что нужно в анальное отверстие лекарство вставлять). К сожалению это не шутка этот случай был в моей практике.
сообщение 2018.12.19 17:18
Народ, не сбивайте с толку нашего товарища, который не знает русский. Он смотрит, что вы тут накалякали и, наверно, пытается переводить.
2 jirijirkas:
Most of the above in Russian is off-topic.
Jirijirkas
сообщение 2018.12.19 17:58
Страна: Чехия
Из: Прага
2 jirijirkas:
Thanks, I understood due to the machine translation what you was talking about.
Elviis
сообщение 2018.12.19 19:41
Из: Мариуполь
Я слышал что некоторые путают ректально и прерорально и то,что ректально пьют как таблетки gigi0000.gif rofl0000.gif
Yes, what is written in Russian is not on the topic, but if translated correctly, it can be funny))))
